Cobra Clunk Underway
Chuckyd973
I installed a new shift cable into my cobra. It took me forever to adjust it so that it would go in and out of gear easily. Now im getting a clunking noise every 1 - 2 minutes underway at full throttle. Any ideas? Btw 1989 21' Bayliner Trophy Hard Top 3.0 Cobra Outdrive.
Chuck
Re: Cobra Clunk Underway
Ayuh,.... You waited Too Long to fix the shift cable Problem,+ now the dog-clutches are worn off...
a70eliminator
Your cable either is still out of adjustment or the clutch engagement teeth (dogs) are hammered.
Chuckyd973
Think its not in gear fully? How can i make an adjustment without taking the drive off? Dont wanna mes up how it shifts now either. It really goes into gear nice and easily
Chuck
skeat
Follow the manual exactly. Did you make sure you had 7 5/8's inches from the cable casing before locking it on the bellcrank in the neutral position? It sounds like you are not getting the full range of motion
Chuckyd973
Yes i checked my cable measurements.....Checked outdrive shift rod. Going from nuetral to forward the shift rod will move 1/4 inch goin from nuetral to reverse the shift rod will move 5/8 inch.......To me this makes no sence.....anyone have any input? I really dont want to mess with my shift cable anymore because it literally shifts with a finger...and the slightest adjustment of the retainer etc etc makes it not want to find teh right gear..Obviously if I have to adjust the shift rod I would assume I would need to adjust the cable at the transom at the very least.
Chuck
bruceb58
Your clutch dogs are gone. No adjustment of the cable is going to help you.
Chuckyd973
The lower unit is relatively new.....Not sure how you can tell the dogs are gone all the way from Cali.....but thanks for your input.
bruceb58
Because I have been in your position before. Bought a boat that had the exact same problem. That's what happens to these drives when the lower shift cable goes out of adjustment or fails and the boat is still driven.
OMC had a major recall in the late 80's for this exact reason. They replaced a lot of gear sets(dog clutches).
Sorry that's not what you want to hear.
skeat
If your drive is in good shape and this only started happening since you replaced the cable it is possible that it is not shot yet, but continue to operate it this way and you can guarantee you will ruin it. There is no easy way to solve this. You have to make sure the cable is adjusted correctly, misadjusted cables were the causes of the Cobra problems. Everything has to operate with a minimum of drag also, so make sure nothing is causing restriction in motion. ie twisted cables, dry trunions etc
Howard Sterndrive
with the full load of a 21 footer on the wee 400 series lower (13 spline propshaft), 2 or 3 good clunks under way and they're done.
I could tell you that from the moon
1990 or 91 they went to the bigger 800 size lower unit on the 3.0
if you are ever shopping for used outdrives look for 15 spline propshaft
Chuckyd973
Howard whats involved with changing out the clutch dogs? You wouldnt happen to have a video on yur site about it would you?
Chuck
Howard Sterndrive
I have no site, but the OMC manual is the best for a step by step on the disassembly and assembly of the lower unit.
I actually have the Cobra upper and lower gearcase videos on VHS here but I have no way of digitizing them and there's several hours worth. another few hours of King Cobra...
Maybe they'll show up on youtube someday
Chuckyd973
I picked up another outdrive on craigslist for $500.00! it works like a Charm! When I have more time i will dissassemble and rebuild the othe unit as a back up.
Chuck
