79MERC1150
- Aug 10, 2008
- 43
Been looking at the CMC tilt-trim or the CMC powered jack plate, with a 5 inch backset. I have a 1980 Astroglass 176 bass rig with a 1979 Mercury 115 outboard. It appears that the CMC unit helps with managing the performance on a boat by placing the engine further back and allowing for adjustments in engine height and angle. Will this unit also create extra stress on the transom, and should the rear section of the boat be reinforced to distrubute the load. It appears that some of the mid 80s Astroglass and Astro boats suffered from transom weakness, although mine was built prior to Procraft's selling of the line, and seems to be pretty sturdy. The upper cap has the fiberglass floor moulded into the cap, so the only wood visable is what can be seen in the rear of the boat around the fuel tank area, and everthing has a thick fiberglass coating on it. The boat is a garage queen, and has not been exposed to the weather. We have checked carefully, and cannot find any weakness in the transom or the hull, I just don't want to create a problem.
