clymer manual question timing
dzer57
First Post
any help would be greatly appreciated
1970 85 hp Johnson outboard
No timing degree marks
Used Joe Reeves Timing
have timing set to B position on flywheel
now I need to-4 degres
manual say turn screw counterclockwise to retard clockwise to advance
each full turn aprox 1 degree
clockwise from in boat or clockwise from behind boat?
- 4 degree I believe I need to retard timing?
from in boat turning clockwise increase lenght of adjustment screw shortning travel of timer base
so I turn screw out 4 turns to retard increase timer base travel
confused about proper way to turn screw
thanks Dzer57
Re: clymer manual question timing
Clockwise and counter clockwise when viewed from the head of the screw.
durban
Master Chief Petty Officer
the screw on the linkage you referring to viewing the head from plugs anticlockwise
