- Apr 24, 2010
- 93
Re: Closer Look at Bell Housing and Shift Cable
Will the gasket make it or do I need another one?
DD
I was going by what someone said when I put the shift cable inside the slide. I put the shift cable nut inside the bellhousing up to 1 thread showing. Could it actually be that I put it too far into the bellhousing? Or do I need to back it out to 4 threads? There is a clicking noise when the helper is turning prop counterclockwise also while I was trying to push cable in.Hi, I had this same issue, Mercruiser manual says in so many words... If it still wont shift you need to recheck & correct the 4 threads you left showing when you put the shift cable in. You probably need to detach the shift cable inside the boat and tighten the cable end at the bellhousing another part of a turn. Run it in to the exact requirement in the guide, I believe it is 4 threads showing but check. When the cable end isn't far enough into the bellhousing it interferes with the shift fork travel, that's your problem.
Oh yes, definitely use a new gasket if the existing one has any questions. Ounce of prevention.
DD
