Closed cooling for Mercruiser 5.0 2013 with cats
tazrig
Re: Closed cooling for Mercruiser 5.0 2013 with cats
Is that $540 each side? So $1080 in addition to the $2,600 kit?! :faint2::faint2::faint2::faint2::faint2::faint2:
agallant80
No, What I was trying to get at was that I could replace the manifolds almost three times for the price of the conversion kit.
Don S
Just got a call from the dealer. $2,600 for the kit. The risers/manifolds(one peace) are $540 each.
I don't understand the one piece statement, have a look at the parts diagram for your engine.
tpenfield
If you are going to be in salt. . . go for the kit, particularly if it is a "FULL" system kit. (and if a FULL system kit is more $$$, it may be worht the extra). The engine will last 20 years or so with salt water going through it, but if/when you go to sell in 5 years or so, a prospective buyer won't really care, and will discredit the boat.
If you have run the boat on a closed cooling system, then the salt water issue/concern would be avoided.
agallant80
I'll see how good end of quarter bonus is to me, 6 more days to go......
As for one peace I was wrong. Dons thanks for pointing that out.
Don S
Did a little price checking, here is MSRP prices. It's kind of scary..
attachment.php
Don S
That kit price is for the cooling kit only. Nothing about the ECM or the hose kit.
Here is the kit itself.
attachment.php
Ayuh,.... Lucky Me,.... No way I'll live long enough to consider buyin' something with That on it....
agallant80
Well perhaps by the time its due the after market people will have started making this stuff.
tazrig
Something else to through into the mix here. I don't know if your new 5.0 is the same as the new 5.7's but 5.7's have a new coating on the inside of the manifolds and elbows that make them much more resistant to salt water. Whereas before if you needed to change the elbows every 5 years or so I was told by Merc that apples to apples it would now be only every 8 years. How long are you planning on keeping the boat for?
agallant80
I may be over thinking this one. The boat will be used on a local lake and taken down to the salt water parhaps 4-6 times a year for a long weekend.
tpenfield
No need for Closed Cooling system, I think the fresh water will take care of the salt.
Don S
Look into Salt-Away , one heck of a lot cheaper than a closed cooling system for a few trips a year.
tazrig
For that little exposure get the above and or just flush with fresh water after the salt and you'll be fine. If you were in and out of the salt all the time it might be different. Sometimes an option like CWC just becomes price prohibitive for the application.
