Clink..Clink..Clink..Gear Make this Noise! Why?
jpdragon
I have a 3.0L Mercruiser (Maxum 1998). It's make a loud clink..clink..clink.. noise from the lower unit when I put in forward or reverse gear.
What could be the problem?
Sometime I have to repeatedly set Neutral -->Forward-->Neutral-->Forward then the gear kick in.
I am attached a picture shown where I heard the sound.
Any help would greatly appreciated.
wire2
Re: Clink..Clink..Clink..Gear Make this Noise! Why?
Is there excessive play in the shift cable(s)? If so, the dog may not be fully engaged, allowing it the ratchet past. If not, keep looking.;)
jerryjerry05
Sounds like the shift cable could be corroded/old and not letting the shift mechanism to work right.
Remove the drive and check the linkage for excessive play.Then replace the shift cable.J
jpdragon
The shift cable is very good shape. I do not see any rusted inside or outside the shift cable. When I shift forward and reverse very easy.
When the engine start, it's hard to put in forward gear. It's doesn't click. I have to try several time and hear a very aggressive noise from the lower unit by the prop.
How should I check for a bad shift cable?
eclark53520
How slowly are you shifting into the gear?
You have to be fairly quick and deliberate with the controls otherwise it will click at you.
Give it a very deliberate push into gear and see if it goes in.
Ayuh,... Take the outdrive Off, 'n inspect the Other end, along with the rest of the linkages....
jpdragon
I had try it slow and fast but still making the loud clink sound from the lower unit. When the gear kick in forward, my boat drive at 5MPH. It's hard for me to put it on the trailer. Well, in order words, there is something wrong here and I can't figure out where. Maybe I should take the lower unit apart and inspect the bearing inside.
eclark53520
Do you have a tachometer?
The idle might be too high.
Squab
Make sure that the adjustment on the starboard riser for the forward and reverse are aqueduct
jpdragon
After adjusting the idle to the minimum level. My boat run a little bit better when shifting the gear forward or reverse. It's doesn't make the loud click click noise anymore.
Thank you for everyone helping respond to this topic.
