jonnyboy32
Thread starter- Joined
- Oct 7, 2011
- 3
I have a 1972 Evinrude 85hp V4 Motor Model #85293R. The motor runs good. As soon as you try to move the throttle to rev up the engine or if you put the engine in gear and move the throttle it will kill the engine instantly. When it does this you hear a clicking under the flywheel in the distributor area of the motor. There is also a wire on top of the motor that goes into the distributor that if you move that it also makes the clicking noise and will not allow you to start the motor. Help!
