Clicking noise 90hp evinrude jet
Doans99
Haven’t ran my motor in about 10 months, started motor at launch and heard this ticking noise. It sounds like it’s coming from top front part of motor around the carbs. The vro is disconnected and primer solenoid is functioning. It doesn’t sound like the clicking increases with rpm or I just can’t hear it and motor appears to be running well other than the click noise. Any ideas on where to to start? Thanks for any assistance. 1991 evinrude v4 90hp jet.
Link to YouTube video of it running. https://youtu.be/aaxoSAUWXDQ
boobie
Do a cylinder drop test on it to see if the click noise changes.
Honorary Supreme Mariner
Is it the VRO pump cycling ??----Put a stick or screwdriver to it and listen to it.
Doans99
Did a cylinder drop test, with no changes to the noise and also the vro pump is not cycling the wires are disconnected to it but also stuck screwdriver to it and listened.
Bosunsmate
Bad reed perhaps?
Try turning the motor while its off by hand, see if it makes a click then or only at operating rpms
boobie
Have you had the flywheel off to see if there's something loose under there ??
