Cleaning off old gaskets
oba97
I'm in the process of replacing a cylinder/water jacket cover gasket but it is not coming off easy. Is there a trick to this that won't damage the cover. Also, should I be cleaning the inside up as well? If so what should I use?
Try a 1/2" wide wood chisel.----Work carefully.-----And no with careful work you will not damage anything.--Or you can buy a spray on gasket softener if you are in a hurry.
charleso
Spray on gasket remover and/or use round abrasive pads. They sell them and the arbor to mount them in a still in the automotive refinishing section in parts stores.
GA_Boater
Gasket spray as mentioned above and I like to use a razor scraper similar to this for less chance of damaging the sealing surface.
oba97
Thanks for the advice. I'll pick up some gasket remover and give that a shot. Any thoughts about cleaning inside the "water jacket" area?
Baylinerchuck
I would use a wire wheel on a drill or die grinder for the inside of the water jacket. Mini scotchbrite abrasive wheels work ok as well. Don't forget the safety glasses.
oba97
Should I be using a gasket sealer when I replace it?
merc850
No; but I would use Anti-corrosion grease on the bolts when reassembling.
