Hello,
What is the best (safe and easy) way to remove mineral deposits from aluminum parts of the outdrive? Deposits look like a white crystalline substance, easy to scrape with a wooden tooth pick (for example). I don?t think this is aluminum oxidation.
The outdrive is in a good shape, paint is OK, but there are some spots here and there. Also, I removed the top cover (for some other reason) and found quite a few deposits on unpainted surfaces there. Nothing to worry about, deposits are not inside of the sealed area holding the outdrive oil, but outside, where the water is allowed to get in. So, I want these surfaces cleaned before I put the top cover back.
Another, may be unrelated question, what for the stuffer plug is? And what is underneath? Can I remove and clean it outside of the drive, or it is better not to touch?
My drive is Alpha One Gen II.
Thank you.
Thank you.
