Cleaning mineral deposits off of outdrive
Fastatv
I just purchased a 1989 model boat in which the PO left in the water ( fresh ) for years. The outdrive has some very thick/nasty deposits of minerals, but I would guess mostly calcium deposits. This is new to me. Is there anything that will remove the deposits besides many hours of sanding. Any suggestions are appreciated. Thanks
alldodge
Re: Cleaning mineral deposits off of outdrive
Try some CLR works pretty well, either that or vinegar.
CLR, Vinegar, lime-away, Muriatic acid, scraper, a high pressure washer, allegedly WD40. Whatever you do....eye and body protection is a must.
Fastatv
Thanks guys for your input. I went to my local Family Dollar and they didn't have the CLR but, she had a product called "The Works" toilet cleaner. Anyway, bought one bottle of it, $1.50, sprayed it on the out-drive....bam! After about 3 quik applications, all deposits were gone. I'm a happy camper. Thanks again!
Yup.. That stuff has hydrochloric acid, chlorine bleach, sodium lauryl sulfate and citric acid.
