Clanton ? Need Part Numbers for Parts on 88 Force 125 HP
Bry21317
The parts that I need are located in the Lower Unit and water Pump.<br /><br />These are gaskets/seals. They are in the Clymers Manual B751-3 on page 450 Diagram 73. <br /><br />Number 62 Locating Disc<br />Number 64 Water Pump Seal<br />Number 51 O-ring<br />Number 49 O-ring<br />Number 56 Shift Rod Seal<br /><br />There is one other part that I need also, but it is not shown in the manual. This is the rubber boot that goes from the engine through the upper front leg cover to allow the exhaust and water to go out through the pee hole. This has craked down the seem. <br /><br />If anyone happens to know these part numbers, could you please post them. I apreciate everyones help on here. You guys are the greatest.<br /><br />Thanks,<br />Bryan Cox
clanton
Re: Clanton ? Need Part Numbers for Parts on 88 Force 125 HP
I dont have a Force parts book, if someone on board cant help, will take a few days to get them.
Bry21317
Thanks Guys. <br /><br />I knew if anyone could find them it would be you guys.<br /><br />I will take the drive to the dealer tommorrow and see if I can find out and will try the Fairwinds Marine tonight.<br /><br />Thanks,<br />Bryan Cox
lonewolf5347
JUST PUT ONE IN LAST YEAR ON A 1994 120,THREW AWAY THE PART NO#.WENT FOR $85.00.PICK IT FROM PEARL GREY MARINE PHONE NO# 631 598 3938 THIS LOCATION IN ON LONG ISLAND N.Y.YEP IT A HARD PIECE OF PLASTIC WITH A CENTER BEARING SEAL .OUTSIDE RING SEAL AND A FRONT SEAL FOR SHIFT ROD? :)
alcan
Hi Bryan<br />If you will post your model# and your email address I will try and send you the imfo you need. Also a breif descrition of where parts are located ie powerhead,ignit,lower unit,etc.
rl29
Hey BRY:<br />You can also go to www.dolleroffshore.com<br />Click on parts and then Force and then go to your Model # and locate the parts and order. It'll show you blown up views of each section and you will be able to get that rubber hose that goes from the motor to the back leg you need. Bought one last year. Doesn't run very good with that water shooting inside the cowl does it. Also found that out last year. Plus you can get everything else you need through them. Good luck!
rl29
