clanton help !!!
ehall1
hey, thanks for the info it really brightened up my day thought it might be junk. when i install a heli-coil do you have to remove the head and if so can i find a head gasket for this year motor.how do i trace the # so i can find out what year motor it is? it's a late 50's 7.5 fleetwin evinrude (pressurized tank no fuel pump).thanks for the help. oh by the way i fished in crystal river once on a vacation at my cousins down by the nuclear plant.first and only shark. have a good one.
clanton
Re: clanton help !!!
I can do it without removing head, pack a lot of grease on drill and tap, to pickup shavings, than tape a small hose on vacuum cleaner and vacuum up what few shavings fell in cylinder. Numbers should be on top of cylinder on pluf that looks like freeze plug. I have book that will give year.
ehall1
thanks for the heli-coil tips, that makes it a lot easier. As for the #s the only thing that looks like a freeze plug is a silver plug on the lower side of the bottom cylinder. those #s are 7524 on top and 11027 below that. the other #s i noticed are on a plate with 4 screws sort of rectangular on the top side of the cylinders (one plate for each cylinder)about 1 1/2"x3". those #s are 202527-1 and 202527-2.
