Circulation Pump on a 1999 Volvo 5.0GL
ky0608na
Would like to attempt to swap out the circulation pump on my own - is this hard, any tips or anything that I need to be aware of?
Re: Circulation Pump on a 1999 Volvo 5.0GL
Ayuh,... Welcome Aboard,...
Naw, it ain't too awfully hard, if yer reasonably Handy, 'n got a few tools...
jclarke2899
Did mine (same engine) about a month ago and went really smoothly. Remove all belts by loosening tension bolts and then the 4 for the pump. No harder than changing oil/filter! Loosen the pulley bolts while the belts are still on and it might be a little easier for you, but that's the only tip I can think of.
