Chyr. cooling
Eric 101
First off i'd like to say thank you to every one who replied to my first post. okay engine details. 72 chrysler 105,2 piece lower unit with a coupler shift, 12 vane impeller. It has two tillson "WB" carbs,type 4 breakerless ignition with motorola reg/rec.It does have a thermostat and a presure relife valve. In all truth i have never known the engine to over heat, but i did find that the thermostat was stuck open. To 12footer, Define exhaust. There are two small ports on the back of the motor and i guess the equivelent of a tail pipe on the bottom of the lower unit and water sputters uot of both, more out of the "tail pipe" please advise. Once again thank you all for your help.
