Re: chrysler voltage regulator
according to cross references, your engine has rectifier only. it would not be surprising if someone used a different unit with regulator. <br />IF you have a very expensive fish finder <br />AND<br />your batteries are in the stern where they are subject to a lot of corrosion<br />AND<br />power for instrument panel comes from a lug clamped to battery cable<br /><br />THEN corroded battery terminals could blow out your fish finder.<br /><br />HOWEVER, if your battery has split posts where the engine cable clamps onto one end and the instrument cable is wingnutted onto the other then corroded terminals combined with rectifier only won't cause electronics failure (unless you have mid-90 engine, in which case it's already just looking for any excuse to break).
