Chrysler Sea King 9.2hp Water Pump info
MotorMan101
I have a old Chrysler sea king which has a bad water pump impeller does anyone know the part number for it or a compatible part? Its 56MM across 15mm thick and on a 12mm shaft.
Nordin
Maybe that one will fit, but the F429065-1 is for 9,2Hp if you check out Mastertech marine site.
To be really sure contact Franz Marine, he will give you the right part number.
