Chrysler impeller replacement
Electrichicken
I have a Chrysler Magnapower 85 Ignition<br />Model#857hd<br />I have removed every bolt and shifting linkage I can think of on the lower half and still can not get it to drop. What could I be doing wrong. I have done this with other motors and have had no problem. I have even removed everything from a spare motor (identical) and have only the drive line with the pump on it hanging out. Is it seazed up or what?
The Marine Doctor
Re: Chrysler impeller replacement
There should be 3 bolts per side. 1 up the exhaust snout. For a total of 7.<br /><br />Then d/c the shifter by removing the cotter pin and the pin.<br /><br />TMD
turtle1173
Hi Richard,<br /><br /> Isn't that something? I have exactly the same motor you have (identical model #'s: 857HD).<br /><br /> I took mine off a few months ago. As TMD said, as long as you have the shift link disconnected and that exhaust bolt out (along with the 3 obvious ones on each side), it should slide right off. In fact, I was surprised when it about fell off mine, after I had removed that exhaust bolt.<br /><br />Shane
Electrichicken
I took the six bolts out, 3 on each side and the exhaust bolts and disconnected the shifting linkage. <br />Can the drive line become seazed in the power head?<br />Thanks for the information.
The Marine Doctor
Yes it is possible for the driveshaft to rust into the crankshaft.<br /><br />TMD
Elysia
i just got a 15hp gamefisher and it was running great water was pissing out now it is not what do i do
Frank Acampora
Electricchicken--- Just to clear it up: After you remove the exhaust snout, then you must reach up inside and remove the hidden bolt at the tail end of the lower unit.
Elysia: You may not realize it but it is bad manners to hijack a thread. If you have a problem, go to the top of the page where it says start a new post. people will then be glad to help.
