chrysler controls trouble hooking them up!
iamcanadianpaul
I have a 60hp chrysler model #608ha,i bought new control cables and i am having trouble getting it to go into gear and there's a button that you pull out and i think it engages reverse???I'm not quite sure where the heck the brackets are to be positioned, Also does any one know what year this might be
bnk999
Re: chrysler controls trouble hooking them up!
On my Chrysler the button you pull out is for nuetral warm up- Basically if you pull that button out you can rev the motor without engaging the propeller -- as far as year it looks like 1984- but not 100% sure -- as far as I can find they only made the 60 hp for 1984-1985 -- maybe someone else on here can verify that for sure
novicetech
With that button out, the motor will never go into gear. it controls neutral warmup only. look at the towershaft and see if the cam is in the way preventing the towershaft from going forward. If it is, I would suggest removing the cables and working the towershaft by hand so you can see where it needs to be adjusted and also to give you a better understanding of how it works. Work slowly, be patient. Remember this is fun.
eurolarva
The motor is from either 1974 or 1975. Pretty rare motor.
iamcanadianpaul
Originally posted by novicetech:<br /> With that button out, the motor will never go into gear. it controls neutral warmup only. look at the towershaft and see if the cam is in the way preventing the towershaft from going forward. If it is, I would suggest removing the cables and working the towershaft by hand so you can see where it needs to be adjusted and also to give you a better understanding of how it works. Work slowly, be patient. Remember this is fun.
iamcanadianpaul
iamcanadianpaul
I'm sorry but i'm new to the outboard motor world could you explain the tower shaft,i'm very mechanical but a rookie to this thanks so much for the help,also i am trying to download some pictures of the motor and controls.
bnk999
here's how my '74 75hp chrysler is:<br />One cable controls the shifting via a rod at the front of the motor that goes down into the motor leg. The other cable controls the carbs as well as the advancing of the distributor via a shaft that has a linkage that connects to the dist- this shaft has a cam that can prevent the motor from going into gear- <br />did the motor have the cables on it before? try to see if you can look at the old cables to see where they attached to the linkages-
eurolarva
This photo is off a 1967 45HP chyrsler. Hope it helps.
www.myfishingpictures.com
[/url][/IMG]
