FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
assuming the engine is the same year as the boat ... that would make it a 1969 chrysler 4 cyl, 105 hp. what should the compression be ?? 120 - 130 ish ?? thanks guys, scott
i may not have been doing the compression test properly. it was the first time i ever triedto do it and the gauge only went up to 60 on all 4 cyliners but then went right back down to zero. as i cranked her over ... thet gauge was back and forth from 0-60 possible stuck rings after sitting 3 years or maybe i just didnt do the check correctly ?? thanks for your replies guys
oh yea ... i do have to drop the starter off at a local shop for a rebulid.... with all 4 plugs in it will not hardy turn the engine over .. all 4 plugs out and it will turn over but still seems to be slow
