Chrysler 9.9 model 92HB parts needed
outboardjake
I am looking for a couple of NLA parts for a 9.9hp chrysler model 92hb. I need a carb kit and needle and seat.(Tillotson MD-144A) I also need the shift push pin that actuates the clutch dog in the lower unit. Thanks for the help.
eurolarva
Re: Chrysler 9.9 model 92HB parts needed
The 18-7037 kit should do you from napa for the carb. Is the shift pin you mentioned in this breakdown? chrysler9.9 <br /><br />If so the part will probably work on your motor.
outboardjake
Thanks for the reply. The napa carb kit is for the Tillitson carb # CO-3A not the MD-144A. Sorry the pin is not in the link you listed. It is the old push style spring return clutch dog. The pin goes in the end of the propshaft and is actuated by a tapered piece on the bottom of the shift rod.<br /><br />Thanks for the help.
