Re: Chrysler 75hp main jet question .066 to a .074
Wrong--Wrong--Wrong! -----Talk to a different old timer.
Yes, bore and stroke is the same with both engines---BUT:
The 75 HP has circular bypass and exhaust ports. The lower unit is a 1.76 to 1 ratio.
The 90 has elongated exhaust ports with about 30% more area and a 2 to1 ratio lower unit. They (the engineers) let the engine rev 500 RPM higher and rate the horsepower at a higher RPM.
Changing jets or carbs will yeild about (0) increase in horsepower. The 75 block is ported to deliver 75! Neither engine delivers a true 75 or 90 Horsepower.
If you mill the head, you will increase compression. You may increase it to the point where you need premium fuel. It is safe to mill the head (or deck the block) .060 inch without causing piston interference.
Porting the 75 block can effectively make it a real 90 BUT: You must elongate the ports downward so the piston does not travel below the bottom of the port opening. THEN, you can either square the ports and streamline the inter-port webs or mill out two webs from each bypass and exhaust.
I currently have an experimental engine waiting for summer. This one was additionally ported therough the bypass side wall and piston skirt. I also added a machined 1/2 inch thick plate tio the exhaust chest to increase volume and decrease backpressure.
In the last photo notice the shape of the original exhaust ports. In the third photo, notice that the exhaust ports are below the top of the piston at bottom dead center. This block started out life as an 85.
And, someone may have switched carbs before you in an effort to gain horsepowe. The 75 usually had three WB carbs with 1 3/16 venturis while the 85 and 90 usually had three WB carbs with 1 5/16 venturis.
And, while you are going whole hog, buy a later junker (after 1879) and swap the block onto the midleg and lower unit from the one piece. The one piece lower unit is by itself about 2-3 MPH faster than the two piece.
