Chrysler 75
Alexdev1200
Hi guys wiring up a second hand motor, when I connect the battery terminals she tries to start, think I have wiring right but obviously not
Honorary Supreme Mariner
It appears to show that you have the cattery cable and starter cable on the same terminal.-------Put starter cable on other side of solenoid I would say.
Alexdev1200
Thanks no the positive is on the solonoid and the negative is on the chassis of the motor or body for a better word
Tassie 1
Postive goes to one large lug,
Cable on other large lug goes to starter motor,
As racerone is saying,
is that what you have?
Alexdev1200
So I just put the negative onto the starter and exactly the same thing happened when I connected the battery, tried to start the motor, the key is even out
Tnstratofam
Here is how the cables are attached on my 75hp Chrysler. The battery cable is connected on the left side of the solenoid, the starter positive cable is connected on the right.
Click image for larger version  Name:	IMG_0319.JPG Views:	2 Size:	1.13 MB ID:	10700107
Tnstratofam
Here is where the negative battery cable is connected on mine. It is boltrf to the block just under the starter behind the carb mount.
82rude
Cant help other than to say keep them going guys!I always loved the looks of the older big Chryslers.Thanks for keeping them alive.
