Again I trouble you guys for advice. I replaced my head gasket about 1 month ago, been out a few times no problems. I went out Sunday, got the overheat buzzer again. Going to do another compression check tonight and see what that says. When I put the head back on last time, I was connecting the wire to the temp sensor and slightly cracked the plastic case of the sensor. So if the the head gasket is blown again, what is the root cause? The motor starts and runs great. Is the motor screwed?
