Chrysler 6hp gearbox oil
mikeya4
Hi all, im very new to boats etc, just picked myself up a 9ft inflatable with alu floor and inflatable keel etc, I got a chrysler 6hp 64hd engine which i haven't even tried yet,do you think this will be enough power to plane? was going to check/change the gearbox oil but I would like know what gearbox oil i need, I cant seem to find much info on this engine does anyone have any specifications on this engine?
thanks
Mike
jay_merrill
Re: Chrysler 6hp gearbox oil
I have the same question in regard to my 1974 Chrysler 10hp motor. As of today, I own both a factory service manual and a factory parts manual, but not much info is given in either one. The accessories section of the parts manual merely states that "Chrysler Outboard Gear Lube" should be used. Mikey's motor (64hd) is a 1976 6hp, so the proper oil for his motor is most likely the same as for mine.
Does anyone know if the LubriMatic, semi-synthetic gear lube sold at Walmart is suitable?
