Chrysler 60hp trigger coil
gillie262
So I had a friend come over tonight who knows a bunch about boat motors and we finally figured out what was causing the motor not to start. One of the trigger coils wasn't producing anything to get the coil to spark. Now I am just trying to figure out where to find another trigger coil. The motor is a 76 Chrysler 60hp 609HA. Please help I almost have it running and it wants to start so bad, I'm so close. I found a model number that works but most places only do repair and return and if that's the case I'm ok with it I just want to get it done.
Nordin
Try Franz Marine he may have new or used. If not there is the R&R as you mention. Check ebay , they are the same for the 4 cyl. engines with MAG II.
I have a couple, BUT I am in Sweden.
gillie262
thanks Nordin, trying to call Franz's now. I have the part number as "F12352-1" or "R12352-1", would that be the correct part number? or do you happen to have something different?
Nordin
The factory partnr. is F123521 the R12352-1 is the R&R from CDI Electronics.
gillie262
Just ordered one from Franz, hopefully this is the missing piece. Thanks Nordin.
