chrysler 55hp firing problem.
welder78
ok i change my coils,cleaned my points and change the condensers.i set the points .20 at (wot) back the throttle 1/8. the 2end plug has little fire not enough to run on its own.it will start then stalls.it was firing good im out of idea.could it be the points not set good enough.plz help im going crazy.:confused:
fucawi
Banned
Re: chrysler 55hp firing problem.
what do you mean set contact at WOT .....that has nothing to do with it ....you set the gap with the heel of the contacts on the highest part of the cam .. ie turn the crankshaft until you get maximum gap and then adjust it to 20 thou...make sure the one piece key is good and ligned up ..this keeps the contact cam ring in allignment with the flywheel magnets .....
BuzzStPoint
What he mean is the Throttle is set to WOT, Then gapped the points at 0.20 gap.
This is how the manual is showing it.
As for your spark. We have to find out if you have an off spark or a weak spark. I would go back and re check the gaps of the point, They are very picky on these old motors. .001 off and the motor will let you know. Next I would look at the condenser.
welder78
ok thank for the help im going to go check the gap again.but do you mean off spark.all i know it got steady fire but weak.and the condenser are new.ill let you know if its the points gap.
fucawi
Banned
I dont care what the manual says ..gap is 20 thou with the heel on the highest part of the cam and you will only be sure if the spark is OK if it will jump a 1/4 in gap in air ..plugs hanging on the wires is no indication nor is the colour of the spark or how fat it is ..Check that key for alignment
welder78
ok so i check the points there right on .20.so i put all back together and it ran like a charm.for a little bit now im back to the same problem.im going to go buy some new points and see if it not that maybe there finish.how can you tell there finish.and by the way fucawi i have not key way.it keep braking so i lock tight the cam.and press pin the flywheel.so it run all independent.
fucawi
Banned
yes I did the same ....ground a flat behind the cam ring and loctite it ...did you fit it " This Side Up"...its marked ....seperate key for flywheel .. So even if it slips it wil still run ..I assume you have battery coil igniton.. mark the flywheel and shaft with paint so you can tell if it moves
welder78
ok so i got it running good.it was a bad spark plug wire.took it out today ran great but dident idle to good,but as soon as it took the hood of it was a hole new motor.idle amazing and had balls like a king.but as soon as i put the hood on went back to a boring old slow hog.anyone know what could it be.i dont like the hood at all.
Jiggz
Is idling rough both on water and when on muffs?
welder78
yes,only when the hood is on.but i dont use muffs i use a barrel.
