Chrysler 55 eci
der
I am looking for any help on how a car eci may be used on my engine. The engine is 1978 Model 559HOM serial No 1321. I bought engine with eci not working and do not know if engine is any good or not as i have nver heard it run. I read on this forum on how a car eci might be used but it did not give all information, any help would be greatfull.
12Footer
Re: Chrysler 55 eci
Der, you need to determine if the motor has no spark or if it does. Try a shot of 2 cycle mix, from a spray bottle, directly into the carb. Make sure the ignition is not grounded (it is when key is off, or lanyard switch has been yanked-out).<br /><br />If it sputters, chances are good, the ignition is ok. If you know for fact that the CD is bad, I would try ebay for a used module.<br />Retrofitting is not recommended, as the ignition potential and heat range will vary greatly. This could cause iether 'holy piston syndrome'(too hot), or insufficiant fuel burn-off (too cool), causing lots of surplus carbon,and port clogging.<br />But yes, it has been done by a briliant gentleman who went by "Schematic". He is rare on iboats these days, as am I. He also was known for picking-out the dialectric sealer in CD packs,and replacing components to get them going again...Somewhat ecentric, but then, most geniuses are :D
der
Re: Chrysler 55 eci
Thank you for reply I checked out the ignition switch and found it to be faulty, it was earthing out the engine eci hence no spark. It was only when I disconnected all the wires and turned over engine by crossing out the starter that I noticed that I had a spark. I then traced the problem to ignition. I replaced it with a car ignition and put push button to stop it. A bit confusing using a push button to stop it but it works.
