Chrysler 55 charging issues
thetadpole
I have a 1973 Chrysler 55 hp it runs like a top but will zap the battery in no time flat. When the motor is running i can unhook the battery and it will die. I noticed that when i connect the battery there will be a "click" from under the flywheel. Also on the terminal strip on the side of the motor there is a purple wire labeled generator that goes to the dashboard but is not connected to anything. Any help will be great
