AOFBoatracer
Thread starter- Joined
- Jun 20, 2008
- 6
In 2003 I bought a really nice 1976 Glaspar Avalon with a color-matched, Chrysler 45 hp (standard ignition) two-cylinder motor from an estate sale. I ran the motor once that year and then stored it covered for five years outside at several locations. I did not receive an owners manual or repair manual with the motor when I bought it used in 2003.
We cleaned up the boat and motor today and I am having trouble getting the motor restarted with a new battery and fresh fuel in a new gas tank -- turns over fine, but the motor won't start. I bought a used, 1985 edition Clymers Chrysler outboard repair manual today at a local booksore that helps me understand the motor a little better. However, the Clymer's manual lacks any good annotated motor layout drawing illustrations for a 45 hp model like mine. What I would like to know is:
1. The two coils on the side of the motor are not numbered. Which coil is the cylinder #1 coil - the top coil?
2. When the motor is timed, is the top cylinder #1? I assume the top cylinder is #1 because Clymers says to time the motor with a piston depth gage in the top spark plug hole.
3. I have the Chrysler motor control unit with a dash-mounted starter switch. Where is the motor kill switch located on a typical mid-1970's installation?
4. The side of the motor control lever has a silver knob that pulls out for cold starting that I assume activates a choke selenoid for the single carb, or does that pull knob perform another function?
Does anyone out there know the answers to these basic questions, or have an owner's manual that describes these parts and functions?
