Chrysler 45 - Flywheel replacement (key shear)
mikezivy
I have a 457HOL 1980 which sheared the flywheel key twice, resulting in very damaged boss taper. Tried to machine but with less then 8 thou off it now sits too low :facepalm: time for another one! Saw one available from a 457H1M which is 1981 I believe - anyone know for certain if that will fit? If not, then where would I source please.
Am based in Sydney, Australia so would need to ship
Thanks
Mike
Nordin
Re: Chrysler 45 - Flywheel replacement (key shear)
If it has the same ignition system then it will fit. The 45Hp had three typs of ign.system. Magneto (coils under the flywheel), battery ign. and Magnapower. The last two had the coils on the powerhead. Magneto typ did not have any charging system.
wickware
Please send a picture or some of your damage and need. Attached is a pic og my 1970 35 HP Chrysler that might be related if it is a Magneto system.
