Please adwise, i mounted a electric starter with starter solenoid and everything on my 35 hp rope started engine, i took all the components from a scrappy 35 hp electric model, i made new cables except for the magneto plate that i never dismantled.Turned the key on, push the choke i works fine but when the solenoid goes down you can see small sparks in the solenoid.And turned the key all the way, starter works fine,tried again and after 3th short start there are suddenly no sparks at all on the sparkplugs,dismantled the black leads from the stator as i assume are the killing leads but no spark at all on the plugs.Please give some tips to follow up.The interlock switch works fine. Before i started the swap i tested the motor with a drilling machine and a socket and there where fat sparks on both sparkplugs.
