chrysler 25hp 1970 (please help)
louisiannalyn
I am from england and am finding it hard to get answers to questions.<br />we are rebuilding an old 25 hp chrysler. it now works well except at low idle spead. also without a wireing diagram we do not know what is where as it was previously wired with non coordinated wire just all black in colour. we have also noticed a battery start has been added but it is not charging the battery just draining it.<br />we have the workshop manuel but no wire diagrams.<br />we have changed plugs points and tightened the plate under the flywheel but still cuts out intemittently. as far as we know the coils are ok.<br />help?<br />also wire diagram if poss <br />lol lyn <br /><br />email....<br />user@the-goodwins.fsnet.co.uk
alcan
Re: chrysler 25hp 1970 (please help)
Hi Louis<br /> Could you post the model # of your motor?
louisiannalyn
Hi Alcan<br /><br />i do not have the plate with the # number on it came without one as it has been rebuilt.<br />I hope these numbers may help<br />on leg tilt...438672<br />on engine bloc cast.....rw458222<br />on carb....461061-1<br />i was told it was aprox 25 yrs old and the manuel and parts list confirm it is model 252ha -253ha<br />could be wrong just guessing i hope this helps in some way.<br />sorry not answered before i am 6 hrs ahead of you.
alcan
Hi Louis<br /> I could not identify you motor as a 1970. How ever I have read your other posts. We know it is at least a 1973 model or newer. I have sent you two different schematics on eletric systems. One is for the mag. system which you state your engine has. This system has no batt. charging function. The other is for an alternator system this system will provide ignit. as well as batt. charging. A mag. system with elect. start is (or was) fairly common. It my not have been factory installed on your model. It sounds as if a previous owner my have installed it. This is really not a bad why to go, so long as your starter rope works. If your batt. goes flat, just pull the rope. Well I hopes this helps a little. Keep us informed.
