chrysler 15hp electrical
broken_lance
Hi all,i have just got a chrysler 15 hp, outboard engine ,the problem is that when i try to connect it up to the battary the wiring over heats ,i dont have the original lead for contecting the motor to the battary ,im using two strands of wiring from battary to the motor,to do this
jerryjerry05
Re: chrysler 15hp electrical
Get at least #4 battery leads.
Anything less will cook!!!
Clean the starter and all connections.J
broken_lance
Thanks jerry,it does not have a starter motor,its a pull start,i dont know what the set up is for this engein,do they need a "rectifier" or something is the voltage to strong im using a car 12 volt battery to do this,as i said before when i conect it up the wiring over heats ????
jerryjerry05
No battery necessary.
You can burn up the points/condenser.
Where did you hook up the battery?Pics?
All you should have to do is pull the cord and it will start.
That is if you have compression/ fuel and spark.
Any wires could be a kill button.Again pics???
Profile,location??You might be close to someone who can help.
broken_lance
new year 2012_20120131_9.jpgnew year 2012_20120131_9_1.jpgnew year 2012_20120131_9_5.jpgnew year 2012_20120131_9_2.jpgnew year 2012_20120131_9_3.jpg
Hi Jerry ,first pf all thankyou for trying to help me in this matter,Im send you some picss,the two wires i have in my hand are off the contector that contects to the batteryi had to cut the end of as it over heated when i first set it up ,thankyou for your time.
chrome dome
l could be wrong but l also think that they could be the kill or stop wires, going to the stop button between the pull handle and tiller
are the wires black or brown?
l have a 10hp magento, which l don't think yours is..or at least isn't now.. and the two wires going to the stop button are black or brown,
wiring diagrams for 15 show black stop wires,
all of them show a starter motor as well,
what are the brackets on the starboard side for?
has someone tried to put some sort of home made starter motor set up on it?
as l said, l could be wrong, been wrong before, will be wrong in the future as well,
LOL
broken_lance
LOL
Hi JERRY ,the two wires are black,the stop button is just at the side of were the two wires to a conector at pops out, as you will see in my pic, this conector has over heated and i cut it of, im makeing the motor a remote thats why brackets on the side it dosent have a starter motor just a pull handle ,the boat that i have is a Norman 22 criuser.I want to know why the wireing over heats when it is connected to the batterynew year 2012_20120201_9.jpgnew year 2012_20120201_9_1.jpgnew year 2012_20120201_9_2.jpgnew year 2012_20120201_9_3.jpgnew year 2012_20120201_9_4.jpg
chrome dome
ya can't blame jerry for the last reply LOL
l'm a tad confused.. but, according to my family it's a permanent condition
so are you converting.. or trying to.. a manual start magneto ignition system to some electric start system?
what type of starter are you going to use?
regulator/rectifier?
stator?
broken_lance
stator?
Hi its a 15hp motor,its a pull start, it dosent have a starter motor fitted ,my problem is when i connnect it direct to the battery the weiring over heats, do i need a regulator ,rectifier if so what type or something ells i dont know about these things ,thanks for any help
chrome dome
l think you'll have to read Jerry's 2nd reply again, specially the bit about not needing a battery to start that motor,
it looks to me that you have a Frankenstein motor, a bit of this 'n' a bit of that of other ignition systems, the wiring certainly does not look original and it looks to have a fuse as well,
