chrysler 140hp help australia
Frank Acampora
Re: chrysler 140hp help australia
Not jealous! I have some decent toys. Again, for the umpteenth time, here is my 60 MPH flat bottom with only a 125 on the back. This was a 40 dollar boat but I probably only have a couple of hundred in it for repairs to handle the horsepower. The cover says 85 for a reason!
hrncjar
u can put any id plate for motor/engin number and stickers on cowling just be a little doggy, no1 will check, only when you race someone and blow them out of the water.
MickLovin
Master Chief Petty Officer
Mate I hate to break it too you, but it still looks like a $40 boat, give the poor thing a paint job, I feel sorry for the old girl :p.
Hey wasn't happy with the 17" prop could only get around 36MPH still not sure of my stupid tacho though.
hrncjar
lol thats kool budd, just need to try a few different props to see what works on my boat then i can buy a stainless one and have an alloy as spair, or just get 2 stainless ones, money isnt too much of an issue. the less i spend the better but nothing good comes cheap.
hrncjar
and yes franka your boat dose look a little sad for $40 but so long she floats and motor works, who cares how the old girl looks so long it dosent sink in the middle of the lake, and no1 around to save you. then you'll be up a creek without a paddle
MickLovin
Ah it's ok try the 21" I hadn't put the spacer on, might go better now.
Frank Acampora
Yes, the boat does look a little worse for wear. When I got her, she was filled to the gunwales with plastic 1/2 gallon ice cream containers. I dumped them out at the marina before I took the boat. The floor had broken stringers and waterlogged foam. SO I ripped out the floor, put in 7 fiberglass stringers and relaid the floor. Transom was only 15 inches so again, I rebuilt it into a 20 inch transom and reinforced it. Previous owner probably played bumper cars with it because the parting line flange was shattered in a number of places. SO: I glassed the cap and hull together then started Bondo to fill in imperfections
The boat was scheduled to have a nice 3 color scheme but With all other projects pressing on me, I never got around to it. Anyway, a pretty paint job won't make it go faster.
Right now it is my test vehicle: She has had a Suzuki 30 4 stroke, And Chrysler 60, 85, 105, 120, Force 90, and 125. Currently she is carrying my old Chrysler 140.
hrncjar
check this out, how mad would this be if we could wear this and use the boat
chrome dome
my son had a 14 ft Volero Dart ( rated for 65 hp, like this one )http://1.bp.blogspot.com/-NmdLSDj8jqo/T6eAQ9KegfI/AAAAAAAABgQ/L4QI7x2PApg/s1600/valero---=.jpg
for some reason he decided to put a 120 hp Chrysler on it,
it chinewalked and porpoised all over he lake, amusing the bystanders a lot,
it wasn't comfortable, pleasant, let alone safe for him or anybody else that had the misfortune to have been on the water at the same time,
too short, too narrow across the beam,
he put a silver band 65 hp merc on it and it was a totally different boat, went like a cut cat and handled much, much better,
my other son bought the sexier version ( lihttp://1.bp.blogspot.com/-_B0BAgnFDp4/T6eADo2YkfI/AAAAAAAABf8/dmSGtVEb7wU/s1600/volero_dart.jpg ke this one ) of that brand, only this one was rated for 85 hp, it came with a 90 V4 evinrude and it handled well too, used a fair bit more fuel though, thirsty buggers those V4's,
hrncjar
when a boat starts to chimwalk you need to start driving it(steering) to counteract the chimwalk, then when you hit faster speeds it stops
MickLovin
This was my Fletcher Arrowflyte 14.5ft, with a 115HP 1984 Suzuki on it, the only difference with my suzuki besides bores etc was it had 4 carbies, fn thing was hard to sync. I did finally have this motor running beautifully, pulling 50+ mph, but it would start to get a bit over the place after 55. it was a great toy, but then I had to buy a half cabin didn't I, not a good move with a degenerative back condition. Now I miss my flecther, wish I had kept it to have this 100hp Chrysler on it, would of been a dream.
BTW not saying mine is bigger than yours ( you know what I mean), just reminiscing
hrncjar
mick did you goto maroon lake today? by any chance saw a boat like yours color and all with chrysler on it, guess what i took mine out was given what i thought was a 22pitch turned out to be 26pitch, anywho was fanging it today getting air n stuff. then motor revvs like crazy, thought i lost my prop in water, trimmed up saw it was still their trimmed it down, started up again put it in gear no propulsion, got someone to tow me back to boat ramp, put it on trailer tried to put it ingear when not running, it locks in gear both forward and reverse, but as soon as i start it and put it in gear it dosent spin the prop. iv stuffed/cooked something yey, took to mechanic he's unsure too, they said it would more than likely be the gearbox, i recon iv stipped the teeth off the shaft that gose into motor, or stripped the spline turner on the block will pull down thru friday. yey
Frank Acampora
If the prop locks in gear both directions, that means the gears are engaged. It is, however possible for a 140 to strip the gears out of an 85 gearbox IF--If the gearbox is a 2-1 ratio. The teeth are much smaller than those in the 1.76 ratio. My 140 DID, after a few years of use, strip the gears. BUT, in that case, It stripped ALL the teeth, not just one or two. It did not lock the prop in either gear and in fact, it was a witch to disassemble because the metal chips locked the bearing carrier into the case.
You were given a prop of which you don't know the history. It is MORE LIKELY that the rubber hub has "spun" When these props spin a hub, most times you can not feel it when turning by hand and it will lock into gear. However, when the engine is put into the water, it may (depending upon the degree of slipping) have zero thrust, even at idle speed or may be able to idle around and slip at higher speeds.
SO: First, remove the prop and using a Magic Marker mark the back and front of the prop and hub with a straight line. Now replace the prop and run the engine in the water. Remove the prop again and look at the line. If it is now broken, indicating the hub has moved, the hub is spun.
You can install a new hub, best solution, try glueing the existing hub with a high quality industrial rubber glue, worst solution, or "pinning" the hub with about 4 set screws, not so good on this type of hub because of the thinness.
The photo is a pinned bronze 10 inch prop for a 50 HP engine. As I said, pinning your prop is a little more difficult because of the thinness of the bronze insert in the rubber hub, but it is still do-able. Go back a ways in this thread and look at the photos of installation of a hub.
MickLovin
I would say it is more likely the lower unit, Take the lower unit off and check spline into the motor, I doubt it is that I would say you have stripped the gears. When you take it off turn the shaft and listen for any crunching noises, you can manually pull the gear shift lever to put into gear and see if it engages. Ring me let me know, don't get a LU off a 3 cylinder either they are geared differently. Alternative to that is come down and try my LU. Frank would have a more comprehensive answer though.
What makes you think you have stripped the shafts top, you more than likely have stripped the gears from it over-revving it then hitting the water again, I doubt you are meant to have a 26" prop on it let alone have it aired for too long :p. You young fellas, just want air time LOL Give us a call, I have done similar to my 75hp but I hit a rock, it would lock in, but you could hear it grinding metal when you turned it by hand.
MickLovin
I knew he was lurking around here LOL
hrncjar
yerh we stuck the prop on my mates boat and he says iv spun the bush, what ever that means, hmm when i finish work tuesday ill go take a look at it, mechanic is shutting shop over long weekend, ill get some answers when i pull the leg off. my company is gay i have to work over long weekend only today off. as public holiday, sat sun mon.
chrome dome
does sound like a spun hub,
there's a prop shop in Brisbane somewhere, l sent up a prop to be re-hubbed a few years ago, don't remember exactly where,
or try the boat wreckers for a second hand one,
l gotta work EVERY day this long weekend...and 14- 17 hour days at that....my missus says my boss is a 'thickhead'
it hurts my feelings when she calls me names like that LOL
MickLovin
Australian prop repairs are in Brisbane, I am happy for you that it is only the prop mate, so hurry up and get down here I need to go for another run :p. Chromey don't worry missus' just talk like that, be like me walk away and ignore her, consequence - no sex for a week or so.
hrncjar
finished work early might come down if thats kool? mick, not gona bring my boat its at mechanics place he wasnt too impresses that i took the boat on his days off and wasnt impressed i brang it back so late too. :) ah well **** happens
