Chrysler 135 proplems
dbedwards
I have a Chrysler 135 with a 13X21 prop on a<br />1974 Beecraft 16' tri-hull. the problem I'm <br />having is the engine won't make operating rpm<br />of 4500-5500 rpm, I get 3800 rpm @ 30 mph <br />with 2 people in the boat, and with more than <br />2 poeple the boat won't even get on plane.<br /><br />The engine starts well and seem to run well<br />comperssions are 120 to 125 ps1.<br />jets are .096 <br />my altitude here is 3500 above sea level<br /><br />Is this to much prop or could the jets be to large? Any help is appriciated.
sony2001
Re: Chrysler 135 proplems
In order of importance I would 1. lower pitch to 19" or 17" cupped. 2. decarbonize twice to raise the psi. closer to mfg's specifications<br />3. go down .002 or .004" in jet size.
Terry H
db...everything sounds right except for wot rpm's. I expect you should get 50kts @ 5500rpms with that 13x21 prop. I would check the ignition system. Points(if you have them) distributer cap, plug wires and especially spark plugs. Make sure your fuel is fresh and mixed properly...omc 2cycle oil or equivalent. That is a good motor, and should take a 16' trihull very fast if running and trimmed properly. I have a similar craft with a 70hp chrysler, with a 13x19 prop I can get 40kts easy. Good luck<br />Thought101
