Chrysler 100HP Model 1007H9A firing order
Fathugo
I am in the process of buying a Chrysler boat with motor, I tested compression and it is good so I decided to move forward. The motor turns on but backfires and am thinking it might be the timing or firing order. I have never worked on an outboard motor but do have good knowledge of auto engines. Does any body know the firing order for a 4 cyl Chrysler 100 HP? I would really appreciate any help. Thanks!!!!!
Frank Acampora
Re: Chrysler 100HP Model 1007H9A firing order
All four cylinder Chrysler and Force engines are 1324. Backfiring can have many causes , from timing to carbs set too lean.
Fathugo
Thank You, I am most grateful for your feedback, I have read a lot of your responses, and I have to say YOU ARE A GENIUS!!!!!!!
