Choke solenoid Johnson 40 hp elec
Kongblom
Hi i have the same engine Johnson 40hp electromagnetic.
My problem is that the other day wenn I tried to start it.. It starts but dies out and smoke start coming from the black wire that comes out off the bottom of the choke solenoid, I think it some how shorten because it came to close to the top off the starter solenoid.
Now I have no spark on the plugs, and I assume the choke solenoid I burned (it got very hot) can I leve without the the choke solenoid...?? And did I maybe Burn out the some thing under the flywheel..??
Hope some one can help..
F_R
Honorary Supreme Mariner
The choke solenoid has nothing at all to do with anything under the flywheel. All it does is close the choke. But since you have no spark you need to pull the flywheel to see what is wrong, even though it is not related to the choke. Or maybe your ignition switch is bad?
Kongblom
Model Nr 40ES69R
Ok I'm pulling the flywheel.. What is the best way to check for sparks.?
Kongblom
As in the key starter..? Can that infect spark...
W2325
You can disconnect the choke solenoid arm, then manually use the choke lever(at least I can on my 1975 evinrude 115hp)
No spark? does the motor crank, but no spark, Did it spark or run before the burnt choke solenoid?
Kongblom
Yes it started and ran for about a 60 sec and then suddenly die, then smoke started to come from the wire that comes out off the bottom off the choke solenoid, the wire was
Completely melted..
I tried test for sparks bye taking out the spark plugs but no spark at all...
Kongblom
Hi again.. Removed the flywheel, and everything was as it should be. Rebuild everything up there last year..
I swapped the cutout switch with a spare one had.. And still no spark.
Ad the moment it's not connected to the boat
I have it in my workshop so it's not hooked up to anything.
