The choke linkage came apart on my 1979 25 hp johnson last time I was out. It is the linkage on the right side of the carb that has two springs on it and helps operate the choke butterfly on the frontside of the carb. This should be super simple but it is wooping my butt for some reason If anyone has a similar motor and could take a pic for me I would be extremely grateful. I have tried to hook it up several times but it seems no matter which way I install it the choke will not open at all or the linkage will not function properly. This old motor shows some wear spots on arm that connects to the linkage so I figured that is where the arm for the choke must ride against but I seem to have something hooked up incorrectly. Any help would be great.
