choice in bottom paint??
yutopia090987
Hello , Everyone
I have a 1978 sea ray which will be in a wet slip for the season here in cleveland ohio. The current bottom paint looks pretty bad, most has been removed with a pressure washer. With so many different types of bottom paint out there i do not know which one to buy. Any suggestions?? Thanks
tpenfield
Re: choice in bottom paint??
There is no right or wrong, as long as you are using a decent brand, etc.
I used Pettit regular old Black ablative with "Slime Reducer" for years and it was fine, the I switched to "ePaint EP-2000" and it was really good. Last year, I tried "Vivid" and it was OK. I liked the ePaint the best.
Home Cookin'
that question can only be answered by someone familiar with that body of water.
Fireman431
Also, unless the paint is the same as the old, you need to make sure it's ALL off. I've been using Petit brands for years and I get up to 6 years in fresh water before repainting. I don't like the ablative, because unless you pull the boat regularly, you'll never know if you have any bare spots. Petit also makes quality non-ablative bottom paints, but as stated, ask around your marina which ones they prefer.
shrew
If you're able to remove the botom paint with a pressure washer, then the paint is not bonding to the hull properly to begin with. This is more than likely why it looked like it was in bad shape. Hull is painted, then begins flaking off leaving bare spots, then the hull is painted again and again. Good paint will not adhere if the first coat is not adhering to the hull to begin with.
Sometimes there is still some mold release left on the hull from the factory. Rarely do people properly prepare the hull for paint by both adequately sanding the gelcoat, then removing all the dirt, dust, debrie before painting. This affects adhesion as well.
1) Have the boat properly sanded. Look into soda blasting.
2) Make sure to use the appropriate solvent to clean the hull afterwards
3) Find a suitable bottom paint for your waters. Planing hulls do well with abalative paint.
4) Choose the paint and then use the paint manufacturers recommended Bottom Coat (Primer and water proofer)
5) apply the botom coat to the manufacturers application instructions.
6) apply bottom paint to the manufacturers application instructions.
Do not listen to anyone who tells you you can get away on the cheap, or by skipping steps. (You don't need that many coats, yadda, yadda, yadda). Very few do it correctly as evedenced by the number of bad bottoms in the boat yard in the fall and spring.
Every year I pull my boat and give it good pressure wash and scrub and it looks like it was just painted. every spring I slap a new coat on and people ask me why I'm bothering to repaint at all.
