Re: Rough and ready '74 Starcraft Chieftan 18' rebuild
Wow is right....
I'm not quite there yet, GA, as I want to get the fuel tank assembly and battery tie downs/wiring done before I restrict access under there.
Fuel tank, new electric sending unit, fill hose, vent hose, and new vent are all in. I just need some hose clamps so I can rig the fuel line and in-line filter and primer bulb. Its the little things like hose clamps that are responsible for the majority of my 700 trips to Lowes. I'm going to use the factory fitting that goes through the port splashwell, and just have one line, as both OBs are OMC, and I can just switch the line to whichever I'm about to run.
I need to figure out another tie down mount, as I wasn't really thinking when I cut the bilge access...there's nothing on the aft side to drill into on the tank's starboard :facepalm::
That plywood on the vertical part of the S/W will be the battery switch mount when the adhesive cures.
EDIT: You can't tell in the pic, but I did use rubber strips under the tank. And I may just go into the transom for the tie down, as the tank can't move aft any more than it is.
PS: I guess I've never had an OB boat with quality fuel line...this stuff I ordered is super thick and nice. I also figured this is a bad place to mess around with cheap crap. I'm really looking forward to not dealing with 6 gallon portable jobs.
