Checking oil in Tilt Trim reservoir
bishop1976
The manual says to put the lower unti in the up position. Does that mean all the way up with the trailering button or as far up as the up switch will allow?
Don S
Re: Checking oil in Tilt Trim reservoir
What are you working on?
bishop1976
Merc Alpha I
Don S
What is this manual you are reading, cause all the Merc pumps on Alphas call for full down/In.
Fishermark
Yep - down and in. Which only makes sense when you think about it. The rams are all the in and the level will be at its fullest. If you have the drive all the way up / trailer, then when the rams are retracted, the pump will overflow.
bishop1976
Full in is what I meant. So full in does mean all the way down. Sorry I have been deathly ill for a few days.
Ayuh,........ That is Correct.....
bishop1976
Thanks guys. Still running high temp. Hope this breaks soon. I have felt like a 470 all week.
PINESOL
geez man if your that bad you should be on life support .... :D
ahhh pull the plug ... :p
bishop1976
A little better today. Went to the doc and got a fist full of pills. Not ym preference but whatever ills this funk...I'll do it.
bhammer
Ensign
Man, like a 470! What you going to the doc for? You should be jumping around like my little peppy 470 does. :D
Got to stand up for the few of us who admit they own one.:)
bishop1976
I've got a 470.....and I feel much better today.
Fiveo Invader
How do you know what type of oil to use? for example I have a 1989 Alpha 1 on a 4.3 merc. mines low but i wasnt sure what to do.
