Checking a Gas Tank
Zetman
I pulled the gas tank out of my boat when re-doing my floor. My question is how do I test to see if this tank is any good. I bought the boat used and had to remove about 5 gallons befor re-moving it. It is a large metal tank out of a 70 GulfStream. I want to make sure it does'nt leak first. The gas that came out looked O.K. ..no rust, just smelled bad. Can I sand and coat the whole tank in some kind of sealant?
Thanks, Zetman
Chris1956
Re: Checking a Gas Tank
Seal up the fill, vent and fuel supply openings and pump a couple of PSI of air into it. Now brush it with soapy water and watch for bubbles. If no bubbles, it doesn't leak.
andy6374
The above advice is correct for testing a tank.
BUT...MAKE SURE that you give the tank NO MORE than 2psi. You'll want a large dial gauge with no more than 10psi range, 5 psi is better. HVAC distributors sell them.
If it checks out then clean thoroughly and then wipe down a few times with wax and grease remove. Sand with an emory cloth and blow the sanding debris off. Then you'll have to use a metal primer, self-etching zinc chromates work the best. Then you can essentially but alot of different epoxy based sealants over the tank. Coal tar epoxy and Interlux Interprotect to name a few.
Zetman
Thankyou for the information..Zet
