Check valve screen
BomberModelA
How important is it to have the screen? What is the purpose of the check valve on a 1984 Johnson 15.
BomberModelA
Re: Check valve screen
New rings,seals,thermostat,etc. put in this motor and afraid to start this without finding out if it will hurt motor to run without screen for break-in.
Daviet
I am afraid I can't ansewer your question, I have never removed one. I am sure someone with knowledge about the valve will chime in and help you out.
Haffiman
The screen is a flame arrestor in case you get a crank-case combustion (sneezing). Has the same function as flame arrestors on cars and inboard engines. If the engine back fires through the carb, it prevents the flames from going into the engine room and setting the boat on fire!
BomberModelA
That would make sense. I guess I'll get around to ordering a screen and putting it on sometime, good thing I'm a firefighter. Thanks.
1946Zephyr
If you think you can start it up without starting a fire, you should be okay, just to hear it run, but I would get one at your convenience.
