check engine
Re: check engine
If that motor is a carb version, the check engine light means there is a vacuum in the fuel line at the motor. If you pump the primer bulb, it should turn off. If you get the alarm steady, you have a restriction (clogged filter, or vent) in your fuel system
CampionGuy
Re: check engine
It means look behind you to see if it's on fire. You are supposed to do that once in a while.
:D:D
Forgive me, I couldn't pass it up.
kenmyfam
Re: check engine
:D:D
LOL, It means to check it is still there !!!! LOL (Just kidding)
