Chattering noise when Dishwasher runs
ST
This has been happening more and more lately. I noticed when this loud chattering noise occurs is when the hot water is flowing into the Dishwasher. The chatters usually stop after about 7-10 seconds or so; but its loud enough, it can be heard from anypart of the house.
I am suspecting that there's a constriction on the copper lines due to the hard water (18 years old plumbing-never had problem before). If this is so, then do I need to "delimed" the copper pipe? If so, do I delime the water heater line only, or all the way to the dishwasher hook up?
Any suggestions from the knows out there is really appreciated! Thanks!
D
DJ
Guest
Re: Chattering noise when Dishwasher runs
Disconnect the water feed line, at the dishwasher, and see if you have a restriction.
Also, there is tyipically a screen where the line enters the dishwasher. Check that also.
ST
djohns19,
I just found out that the feed line is connected to a valve (also controls the hot water side of the kitchen faucet), and it was only slightly open. I opened it all the way now, and will see in few days if this fix the problem.
Thanks for the tip!
ST
djohns19,
I made a trial wash this morning, no chatterring occured. Good sign! Let's give it a few more wash/trials, then we can be more positive, right?
Boy, I have never been more anxious to run the dishwashers than now, John! d:) But it usually take a couple of days (just the wife and I) to load it up...:'(
ST
Update:
I've run it 4 times so far, no more chattering heard! I am convinced now that that was it. (hot water valve opening too narrow).
Thanks again for the great tip, djohns19!
D
DJ
Guest
Cool!8)
Thanks for the feedback!
