Chassis ground on a pontoon boat
W2HENDE
Got a new radio and amp and speakers for the boat.
I noticed that the active subs and radio need a chassis ground
it is a 24 ft fisher pontoon with mercury 50hr
how do i chassis ground the pontoon
thanks
lee
Silvertip
Honorary Supreme Mariner
Re: Chassis ground on a pontoon boat
There is no chassis ground on a pontoon. That term comes from the auto world where the frame or body of the vehicle is grounded via a bonding strap (or two) to the negative terminal of the battery. So chassis ground whether it is in a car or a boat means the NEGATIVE terminal of the battery.
TerryMSU
That was my thought as well. In theory, one could connect the ground to the frame of the pontoon, BUT I would strongly discourage it. The ground will oxidize and potentially damage the aluminum frame by means of electrolysis. Wire the grounds together with HEAVY wire. Based on the references to a chassis ground, I suspect that the sound system is an automotive system, not a marine system. If so, bad news... I know that there are a lot of people who disagree with this, but that automotive quality system will not last in a marine environment. This is true whether this is a salt water or fresh water system. It will be worse in salt air, or an extreme humidity environment.
TerryMSU
