Alumarine
- Feb 22, 2005
- 3,759
Hi there. I'm really hot, really tired and really hungry and I got a no spark issue.
Went to fire up my 74 Mercruiser 140 for the first time this year and no spark.
Fired up fine last fall. Brother in law borrowed starter and temp gauge to try in his boat. May have wiring issues now.
This system uses an external resister type coil
Resister wire checks out ok from the coil to the large wiring plug.
Have 12 volts on the ignition/resister wire. Thought I should have less.
Tried to hot wire it by running 12 volts to + side of coil. No spark.
Just have ignition wire and starter wire to + side and distributor to - side.
Any suggestions? Is it ok to run 12 volts direct to coil for a short time?
Thanks - gonna take a break from the sun.
