Charging the starter battery
dozer1013
Basically just would like to know if an 86 Mariner Marathon 135 actually charges the starter battery when running :confused:
Thanks
Re: Charging the starter battery
It is supposed to. That motor should have a rectifier and a voltage regulator, according to the parts list. Rectifiers blow all the time.
dozer1013
is there an easy way to test the rectifier?
And where about is it located?
Dave1027
If the voltage goes to between 13 and 16 after starting then it's a safe bet the rectifier/regulator is working. You could ohm out the diodes.
Dozer, According to the parts list the rectifier will be port, top, rear of the motor. It will be black plastic, rectangle with three connections. It should have two yellow wires on it and a red.
