charging system
pokermgr1
I went out today and had little to no battery power. I know that batteries are strong. I keep reading somethign about a run/charge switch. Where would I find that? I have a 1994 Stratos 270. Any other reason why I might have not gotten a charge as noramal? I have 3 batts total. I think 2 of them are for the troller and the fish finders. The other is just for the engine. Does that sound right?
Chris1956
Honorary Supreme Mariner
Re: charging system
Sounds like you have some kind of short. Disconnect all batteries. Now insert an ammeter (multimeter set on highest scale works as well), in series with one battery's pos post and the red cable for that battery. Just touch it to see if you get a reading (remember no gas fuems can be present), so you do not burn out the meter. Now reduce the scale on the ammeter until you get a good reading. Anything under 1/2 Amp is insignificant.
BTW all motors automatically charge the batteries, if they are connected properly. There is no run/charge switch that I know of.
John_S
Re: charging system
Did you rely on just the outboard to charge or did you plug in the charger and fully charge? It is typical for having two batteries for the trolling motor (24V) and one for starting. Was all the batteries dead or just the starting battery?
If they were fully charged, I'd look for something left on or an auto-bilge pump stuck on, airater etc. If it is not something obvious, it is time for the ammeter or multimeter. How much time past since they were fully charged?
Silvertip
Re: charging system
Let's start at the beginning. You said you had little to no battery power. The missing point is "battery power to WHAT". If you mean to the engine because the starter wouldn't turn it over that's one issue. If you mean the troller had little to no power that's another. So you first need to determine which batteries "for sure" power what devices and then tell us what is not working. Next, is the trolling motor a 12 volt, 24 volt or combination 12 OR 24 volt? That's important because it determines whether two of the batteries are dedicated to the troller or not. If you have a 12 volt motor only one of the three batteries may be dedicated to the troller. So here's the scenario: for 24 volt trollers TWO of the batteries are ESSENTIAL and therefore dedicated to the troller and the third is dedicated to the engine for starting. If you have a 12 volt troller, one battery may be dedicated to it, the second is backup for the engine and the third is dedicated to the engine. As for a RUN/CHARGE switch it will be on the trolling motor receptacle panel at the bow of the boat if there is one AND the boat would need to be wired for a combo 12/24 volt motor. Not all boats have them (thank goodness for that). "Thinking" the batteries are strong and "knowing" they are strong (as in fully charged) are two different things. The only way you know is to physically check them. Lastly, how do you normally charge the batteries? You didn't tell us what engine you have but if you are depending on the typical outboard to keep three batteries charged the engine is not capable of doing that. So you need to provide us with much more detail than you have. And by the way -- if there was a short fuse(s) would be blown and there is no such thing as a "partial" short. Intermittent shorts yes -- but not partial.
pokermgr1
Re: charging system
Update
I left a light on and it drained my trolling motor battery. I have an onboard charger. I checked the batteries after charging them and 1 had no juice, 1 was charged in full.
New question, I am needing to get a new trolling motor. I don't know how many # the one I have is b/c it has no model numbers, decals, etc. I do know that it will not hold up to a 25 mph wind. The boat is a 18' stratos. How big of a troller do you recomend?
Silvertip
Re: charging system
For 25 MPH winds you need a 70# 24 volt unit minimum.
